Subject: Request for site review!
Mahkameh
25 Sep 2008 10:14 AM
Elportondemijas.es
I would like you to take a look and tell me how can I speed it up and any other suggestions. We are also looking for advisers if any one is intrested.
26 Sep 2008 9:06 AM
hello,
The one comment I have is that I found the small text hard to read, and on the home page I found the main content pane hard to understand, there seems to be too much information without any white space, perhaps adding a bit of space and increasing the text size would make it easier to read.
Forums > Users Lounge > Site Review Please! > Request for site review!
