Subject: Best so far for me
mortymoose
06 Sep 2008 12:55 AM
This skin is CSS standard compliant.  I understand though that the solpart menu causes it not to validate.
What menu modules do you you guys and gals find the best, that also provide standard compliant markup?
I had a lot of fun with this site.  It is the first site that I created an XML page for the Text Editor to use.  That way my users have a drop down list of styles I want them to use.  As I said it is the best so far, but I have a long way to get to where I would like to be.
TouchPoints Ministry
~Michael Silva
CornerPixel
www.cornerpixel.net
06 Sep 2008 9:47 AM
Forums > Users Lounge > Site Review Please! > Best so far for me
