Subject: New CSS site feedback please!
dp6ai
05 Sep 2008 7:30 AM
I've just designed my first CSS site. I'm not sure how well it works because the client was so keen to have a fixed height and width (not always my preference) www.cotters.co.uk Brutally honest feedback please!! EDIT: I'm interested to see whether I've added the Flash elements in properly?
puuri
05 Sep 2008 7:47 PM
Everything, including the Flash elements, seemed to work fine during my viewing. I was trying to find some critique for you, but am having trouble finding any. I think the site looks really good. I like the way you change the bottom links to reflect the sub-menus when navigating through the 'Our Services' section. I was just wondering if you could change it to display these links when even on the top level 'Our Services' page? Just a thought. I was also wondering if Manufactsure was a typo on the menu until I visited the page and saw that it was a trademark term. Is that something that could be denoted on the menu itself? These are minor comments that were a stretch to come up with after viewing the nice job you did with this site.
jcator
09 Oct 2008 9:57 PM
using IE 6 when I hover contact us the sub menu shows up on far left and contact us disappears.
Forums > Users Lounge > Site Review Please! > New CSS site feedback please!
