Subject: Does this website look OK?
momwriter
04 Jun 2008 1:36 PM
www.chillifreeze.com
It was done entirely using Dot net nuke and we are all writers, so we have no design expertise
Do you guys like the look? Any suggested changes?
Anyone from here can help us with the changes?
momwriter
04 Jun 2008 1:36 PM
We wanted to have html pages with DNN so we would have more control over how the website looked but that is not possible, right?
04 Jun 2008 5:45 PM
Your website looks very nice.
You can have html pages, and you can have complete control over how the pages look with a combination of skins, styling, etc.
If you want to have pages that are "mostly" html. I would put a single html module inside of a skin with a single content pane and nothing else. Then you can paste your html into the module.
But, as you learn more about DotNetNuke, you'll probably find additional ways to do things that work for you.
05 Jun 2008 3:58 AM
You may want to double check your page settings on this page:
http://www.chillifreeze.com/WritingResources/tabid/458/Default.aspx
I noticed that a view / edit radio button displays at the top of the page
Forums > Users Lounge > Site Review Please! > Does this website look OK?
