Subject: CSS Skin For Review + .doctype.xml question
carizzio
07 May 2008 2:38 PM
I'm like 99% done with a skin-redo for a client.
Valley Association of Realtors
The older version I did about 18 months ago was absolutely hideous and table-based.  The client wanted to start incorporating the vendors module and I couldn't stomach working on the site the way it was so I whipped together a mockup JPEG they approved and tossed this new skin up.
Any kind of review/suggestions would be greately appreciated.
Standards Compliance Mode Question.
The Portal is running on a 4.3.4 Installation of DNN.  Is this why my .doctype.xml is not being recognized and the site is still running in Quirks Mode? (I hate that ugly red X in the top right of FF)
Thanks in advance and..
Happy Skinning Everyone!
09 May 2008 9:23 AM
Looks good - The only thing I noticed was to check your terms token - you currently have text - [Terms of Use]
use: [TERMS]
and it should work ok.
- DOCTYPE - check out this page for a solution to your DNN version:
Browser Quirks, Standard Compliance modes and Doc Types
Cheers!
Forums > Users Lounge > Site Review Please! > CSS Skin For Review + .doctype.xml question
My Server's Event Viewer by mgordon
Help!  Not sure what's going on.  Every ten minutes, on the dot, I am getting an Information log in ...
RE: style search CSS or XML by mmcinulty
Hi Leei was able to replicate the mouse over affect by using the css, the problem is that i still ha...
Still no luck with this feed. I can get both of these links to render if pasted in Internet Explore...
thanks for posting info,
03.04.00 Thanks Bryan
