| RE: PowerDNN Review by Declic Video FX |
| Hello, +1, I am also very happy !! I *was* hosted with WebHost4Life since many years with MS V... |
| RE: WebHost4Life by Declic Video FX |
| Same for me Richard.... I am (was?) hosted with WebHost4Life since many years with MS VPS account... |
| RE: Home Page Login Question by BCRose |
| Thanks for the quick reply. Sorry for being a dummy but where do I edit a skin at? Or the style sh... |
| RE: Home Page Login Question by jncraig |
| The LOGIN and REGISTER links are Skin Objects that are included in your skin file. The easiest way ... |
| I would like to remove the 'LOGIN' text from the top right of my pages. How can I do this? I tri... |
| RE: Strange behaviour when pressing login by jncraig |
| Yes, that is the one. |
| RE: Strange behaviour when pressing login by pontus66 |
| Thanks for the tip. I will let my programmer check it out.
This is the module you're referring t... |
| RE: extending user accounts for membership by jncraig |
| Try these:User Accounts new features User Accounts and User Settings Enforcing Terms and Conditions ... |
| RE: DataSprings Dynamic Forms Demo #20 Question by jncraig |
| There are some nice examples on the Data Springs site. The more complicated demos do require some s... |
| RE: Dynamic Forms Email From User/Pass by jncraig |
| If the SMTP server is configured so that it will not send email from arbitrary email addresses, I wo... |
| Glad that you got it solved.There is a free module available from Iowa Computer Gurus that automates... |
| extending user accounts for membership by cbwardsr |
| could someone pt me in the direction of some literature regarding adding fields to user accounts.
| Problem solved!Though I am not sure how. I haven't talked to my programmer yet, but he sent a mail a... |
| Dynamic Forms Email From User/Pass by Trusted |
| Hello everyone,
We have a client with restrictive mail policies so a username and password is requi... |
| Using Default Template for Pages by toddre |
| I have a default template that I would like all Admins to use when creating new pages. I would also ... |
| RE: DataSprings Dynamic Forms Demo #20 Question by aggiedan97 |
| Thanks for the feedback. I will let you know what I find and I have posted on the DS forum. So far ... |
| RE: ITextSharp by leesykes |
| Glad you got it sorted, what was the solution for anyone else searching for this problem? |
| RE: DataSprings Dynamic Forms Demo #20 Question by leesykes |
| Hello,This is not something I have explored yet, but as it happens I am going to be building a form ... |
| I am attempting to build an order form that subtotals a section that is based on the 'TotalByQuan&nb... |
| RE: Shared Same content in Sub portals/ Childportals by leesykes |
| Hello,Your other option is to use RSS feeds for sharing content. Setup a module on your main site su... |
