Subject: Advice on catalog module
shraga
21 Dec 2009 10:56 PM
I need to put on a catalog of products asap.  It's intended to be something between product  catalog and a portfolio gallery, meaning, nice artistic look and attractive navigation.  I may need to put a cart on it in the future, but the display part of it is urgent.
Any advice for a module that could fit these requirements the best, free or not?
I know this is a blurry question.  I'd appriciate any advise.  Thanks
03 Jan 2010 10:00 PM
Ventrian's Property Manager might be something to look at.
shraga
03 Jan 2010 10:36 PM
Thanks you, Joe. From the demos of the module it indeed looks like a good possibility for this project, I'll try it tomorrow. I am impressed that you connected this module with my post. It's greatly appreciated. shraga
Forums > Users Lounge > Everything Else > Advice on catalog module
Non Standard Port with DNN 5+ by thejudge
Hello Some time back we started tinkering with DNN v5, however we couldn't get it to work when tr...
RE: Community Edition Question by idesofmarch
Thanks a million! This is my first project in dotnetnuke. I've always done Joomla or Drupal. But I d...
Flash in the HTML Module-Source Code by robmacker
Here is the source Flash files for the implementation question i have below. Thank you for lookin...
Windows 7 Install gone wrong by RichardSletcher
Hi I have just attempted to install DNN 5.2 on Windows 7 Pro. I followed you video tutorial but I n...
RE: Module Advanced Setting by jncraig
The module contents is distinct and separate from the Module's container on a particular page. Wh...
RE: Community Edition Question by jncraig
The UDT Module has a new name: Form and List. Look for that. If it is not installed, it shoul...
DataSpring Opt In Module - Scheduler Question by wynnjon
Hey-I was wondering if anything special had to be done to keep the site alive so that the scheduler ...
RE: the now content not showing and still showing the old one by jncraig
You probably can't. Your browser is caching the old flash file, and CRTL-F5 forces a reload. If yo...
RE: Nav Menu v2 for DotNetNuke v5 - Issue 52 by jncraig
Here is a nice little blog entry on the subject.(Basically, though, this gives you a nice and clean ...
RE: Flash in the HTML Module by robmacker
OK, so i commented out my AC_RunActiveContent.js file and my HTML module runs the same -- telling me...
RE: Flash in the HTML Module by mcmanta
I had the same problem before. I noticed I had some HTML tags from some error text I copied. I was a...
Thanks for the reply Joe, The way my hosting company does things they don't have per say host hea...
Wow, why does the forum format my question to make it basically unreadable?? I certainly did not typ...
Hello members! I have a simple flash application that was written for an HTML page and i'm trying...
Send email with Dynamic Forms Results by jesp17
Hello, Is there a way to automatically generate a report with all form results and then send this r...
I'm learning a lot just browsing around here. Wish I could delete my question below. Oh well. Wher...
RE: DNN Site crashed after module install by mcmanta
I found a work around. Looks like the module replaces the Telerik.Web.UI located in the bin folder o...
RE: iHostASP by chandirika
Hi,I am reselling account with this http://www.goresellers.com/ site ,for my web site's web hosting...
the now content not showing and still showing the old one by wael_e
after i uploading the new contenct in my website and i uploading static html page have introdaction ...
RE: Regular Expression by jumatthey
Hi, Thank you very much Mark. It is indeed a name I am checking. Thank you for your help, very mu...
DNN Creative Subscribe
