Subject: User Management Modules
Bill
18 Dec 2009 3:06 PM
URGENT, Time sensitive.... Is there a module that allows listing/seeing all users and sorting by items such as security role plus including all data captured at input? I have a variety of user types and the population has tripled and soon could grow by an order of magnitude. I discovered that I can only see 10 at a time in User Accounts and then only see the basic infomration one at a time even through edit. I can't even tell who is registering versus subscribing. I need something that allows me to see details on every user inlcuding their roles, etc. Free would be best but if I need to buy a module I just need to know if something is availabel. Thanks.
19 Dec 2009 4:16 AM
You can configure the User Accounts page to show more than 10 at a time.
I've not used any other modules to show more detail.
19 Dec 2009 4:18 AM
There are several User Management modules available on Snowcovered.
Forums > Users Lounge > Everything Else > User Management Modules
RE: Skin Header by mcmanta
I'm not aware of any.
RE: Skin Header by WinXnet
RE: Slow login by jncraig
