Subject: Background colour
Pete
03 Jul 2009 10:21 PM
Sorry if this is a real dumb question, I've been experimenting with the Vortex skin and I have changed the  background colour (to something vivid so it stands out) in the skin CSS pagemaster id, no problem there but after uploading I can see a white margin at the bottom of the screen that I can't get rid of.  BTW, the skinmaster background colour is set at white. The LH, Top and RH works fine, there no margins. I played around with the CSS file but can't find a fix.
Some words of wisdom please.
Pete
04 Jul 2009 7:06 AM
Pete
04 Jul 2009 7:45 PM
Thanks for the reply Joe,
The bottom margin seems to be in Firefox only, IE and Safari displays as expected.
I went to CSS edit as you suggested and changed the class .pagemaster height fromm 100% to 120%, that seems to have fixed it.
Thanks for your help.
Pete
Forums > Users Lounge > Everything Else > Background colour
That will work.
