| RE: DNN Live site not displaying by michellb |
| Yes, I can access the data in my database. The web.config file is setup with the correct connection... |
| RE: DNN Video Player module by acandael |
| great module. I had trouble playing an .mp4 movie. After purchasing and installing the DNN Video Pla... |
| Links Directly To Files With Login Prompt by ALPAdnnUser |
| Is there any tool/module that is out there that will let me email a link to a file (that is secured ... |
| RE: Skin missing banner and menu when ctl is used in the url by swelch |
| No, I still don't have a solution for this |
| RE: Fun? with styling of Home.aspx by dkemp@karrtuttle.com |
| Thanks so much for your help. The View Source tip, so simple, was effective. I went right to the p... |
| RE: How to slow down the menu by datamark |
| Thanks again Lee. I'll look into that garden menu again if it is that simple to install. No changes ... |
| RE: How to slow down the menu by leesykes |
| I can't remember without doing some digging into older skins what the parameters are for the animati... |
| RE: Non Standard Port with DNN 5+ by jncraig |
| In web.config ... "set UsePortNumber to true to preserve the port number if you're using a port numb... |
| RE: Server Error in '/' Application. by jncraig |
| Could you provide a bit more information? There should be some text that accompanies this. |
| RE: DotNetNuke 5.3.0 Released by leesykes |
| very interesting! |
| RE: How to upgrade core module? by leesykes |
| All you need to do is install the downloaded core module in exactly the same way as you would instal... |
| RE: Fun? with styling of Home.aspx by jncraig |
| If the styles are not defined in a Text/HTML module, they might be defined in either the Header or F... |
| DotNetNuke 5.3.0 Released by jncraig |
| Joe Brinkman's blog has all of the details. But, I found this interesting:New FeaturesTemplated Use... |
| RE: Removing View and Edit Buttons by mikehj |
| Joseph - you are right on the money. I missed a security setting on the page. Thanks |
| How to upgrade core module? by LeeWebDev |
| I can't believe this is so hard to find instructions for, but how do I upgrade to the latest version... |
| Thanks Lee, I still have older skins on some of my sites that are using the Solpart menu. So I was r... |
| RE: DataSpring Opt In Module - Scheduler Question by wynnjon |
| Thank you! Your advice and training is always so great and always appreciated! |
| Are you referring to the Nav menu rather than SolPartMenu?NavMenu has been default menu since around... |
| RE: Change Registration Redirect? by leesykes |
| Yes this site uses standard registration.DataSprings Dynamic Registration replaces the original, it ... |
| RE: Using Xenu Link Sleuth to Spot and Improve External Links in a Domain by leesykes |
| So, are these external links that are linking into your website that no longer exist?If that is the ... |
