Subject: what means report in forum module?
shootermv
09 Apr 2008 12:45 PM
i saw that it add a new message...why it doing this?
09 Apr 2008 7:11 PM
"Report" means that a user can "report" a message to a forum administator. This is done to alert the administrator that a user objects, for whatever reason, to a message. Issues like profanity, inappropriate postings, etc. are the usual kinds of complaints.
Forums > Users Lounge > Everything Else > what means report in forum module?
