Subject: Adding security roles
tmoran1173
05 Apr 2008 4:32 PM
Is there a way to create a link that will subcribe a user to a public security role?  Instead of making them navigate all the way to their profile and click Subscribe?
Thanks in advance,
Tom
06 Apr 2008 3:03 PM
I'm not aware of one. On the other hand, it wouldn't be "too hard" to create a module that would do that ...
Forums > Users Lounge > Everything Else > Adding security roles
