Subject: ASP.NET Developer with DotNetNuke - IMMEDIATE NEED - Dallas, TX
MaryLowy
31 Mar 2008 11:43 AM
Client is seeking a ASP.net developer with Javascript and AJAX and some ORM Solution.
Must has experience with ORM solution like NHibernate, SubSonic, or Castle ActiveRecord.
Strong web development skills are required. (Not just ASP.NET but strong JavaScript and AJAX are a must)
Must be able to interface with the business quite frequently so good verbal and written communication skills are paramount.
A big plus if the developer has had experience with DotNetNuke.
6 month contract in Downtown Dallas.
Email marylowy@insourcegroup.com if interested.
Forums > Users Lounge > Everything Else > ASP.NET Developer with DotNetNuke - IMMEDIATE NEED - Dallas, TX
Member log in by HUGHD37IUOE
Video Problem by icdlbake
