Subject: Career Opportunity
Nuke Master I
Nuke Master I
19 Mar 2008 8:32 PM
Consulting Associate/Senior Developer: .Net Technologies
We are seeking an innovative, technically-savvy, and high-energy
developer to fill a client-facing Consulting Associate/Senior
Developer position.  We are seeking a technology consultant and
software developer with a sound understanding of the .Net platform,
C#, and SQL; experience with web development (ASP.net) and DotNetNuke
Web Application Framework  is desirable. The incumbent must have good
client-facing skills and the ability to lead projects from vision to
delivery along with other development resources.
We expect you to provide modern and critical perspective to identify
and formulate cost-effective solutions consistent with clients'
strategic goals. The job entails coordinating/supervising on-shore and
off-shore development resources and as well as working closely with
clients to ensure business needs are met by implemented solutions.
Technology Skills Required: .Net, C#, ASP.net, Database development
(SQL) experience are a must.  A minimum of 3 years of full SDLC
experience on the Microsoft .Net platform is required.
Other Minimum Qualifications: A desire to be great. Experience in a
healthcare or healthcare support industry is a plus. A quantitative
degree (computer science & engineering, economics, etc) is preferred
though not required. MBA or other graduate degree is preferred though
not required. Compensation will be competitive to aggressive with a
performance-driven bonus. Opportunity to join partnership commensurate
with results.
Contact Information:
Audacious Inquiry, LLC
9250 Bendix Road, Suite 215
Columbia, Maryland 21045
(301) 560-6999
(301) 560-4154 fax
Forums > Users Lounge > Everything Else > Career Opportunity
Member log in by HUGHD37IUOE
Video Problem by icdlbake
