Subject: adding lists to membership profile
dnnuknewbie
19 Mar 2008 7:35 AM
Greetings,
I need to add long pick lists to the membership files. I can see how it is done via manual route but wondering if its possible just to paste in the lists via the database.
Any useful tools out there to do this job. Thanks.
19 Mar 2008 8:38 AM
I'm not aware of any tools.
Forums > Users Lounge > Everything Else > adding lists to membership profile
