Subject: best html editors
dnnuknewbie
19 Mar 2008 7:34 AM
Greetings,
We are using CKEditor with 4.8.1 but is creating extra lines etc., and is a real pain to get the formating right. Any suggestions on an alternative test editor for dotnetnuke (paid or otherwise) thanks.
19 Mar 2008 8:44 AM
The default "format" of the FCK editor is to use < p > tags to wrap text "paragraphs."  The "Normal (div)" format uses < div > tages.
If you look at Styling and formatting (part 2) – Text / HTML module and FCKEditor youwill see how you can define formats and styles that match your preferences.
anderson
18 May 2008 6:56 AM
hi everyone, this is jack anderson from california. am newbie to this community. i really appreciate the informations which you mentioned above. i like to know some more details about this can anyone provide me please ?....
Jack Anderson,
18 May 2008 8:25 AM
Sure, try these:
Forums > Users Lounge > Everything Else > best html editors
WOW GOLD by wowgolds987
RE: Pop up window by yerann
RE: Events calendar by mjbieg
