Subject: Cannot Create New Portal
jboudreaux
18 Mar 2008 10:37 AM
Has anyone had this problem using DotNetNuke 3.something:
When trying to Create A New Portal, the screen simply refreshes and you are returned to the top of the page.
This is something that has just started happening.
Has anyone experience this problem and can anyone point out the possible problem/fix?
JB
18 Mar 2008 6:51 PM
Check the event log to see if any errors are logged. You might also want to check the website's Portals directory to see if any subdirectories are created.
Forums > Users Lounge > Everything Else > Cannot Create New Portal
