Subject: Best tool to record video tutorials?
GeoffreyMH
16 Mar 2008 4:48 PM
Hi Lee
Still providing a great service.
Just one question: what tool do you use to record these video tutorials and how do you like it?
Does anyone else reading this use other tools, and how do they feel about them?
Regards
Geoffrey
BaronRojoSJ
16 Mar 2008 8:52 PM
Camtasia Studio is very nice and fairly inexpensive.
Take care,
Steve
16 Mar 2008 10:19 PM
Lee uses Adobe Captivate.  See this thread:
http://www.dnncreative.com/Forum/tabid/88/view/topic/forumid/3/postid/5209/Default.aspx
17 Mar 2008 4:33 AM
Glad to hear the site is useful, yes the 2 main ones are captivate and camtasia - both have pros and cons. - If you are looking for free you may want to check out the Jing project
Forums > Users Lounge > Everything Else > Best tool to record video tutorials?
