Subject: User details for mailing list
gilliancowe
10 Mar 2008 6:21 PM
I have a site that needs no registration so I have removed the login/register from the skin.
I want to have a module on some pages of my site that says 'sign up for our newsletter'. I only need to collect name and an email address, then I want to use this information to create a mailing list.
What would be the best way to do this in DNN?
I thought of the Account Login module, and setting up a newsletter group of users, but the module asks people to login. Login to what though? I don't need them to login. Only to register.
New to DNN, any help gratefully appreciated.
Gillian
rshevlin
10 Mar 2008 7:04 PM
Go to Snowcovered.com and buy Opt In Email Module. The best there is.
gilliancowe
11 Mar 2008 11:25 AM
Thanks, that looks like an excellent module.
Forums > Users Lounge > Everything Else > User details for mailing list
