Subject: Landmark interview
cd@viamedia.dk
07 Mar 2008 3:04 AM
Hi Lee,
I wonder if you know enough about Landmark?  Have you read the very critical articles about this - some are calling it a sect, trying to use peoples longing for a God where Landmark becomes the God ??
e.g. www.apologeticsindex.org/l30.html
Carsten
14 Mar 2008 6:14 AM
Thanks for the info, I was not aware of these articles. But, at the moment I am going to leave that interview on the website because the interview is not promoting landmark, it is focused on the use of languages and RTL text. it is a useful resource for RTL text so I do not particularly want to remove the article.
Thanks for bringing this to my attention,
Lee
Forums > Users Lounge > Everything Else > Landmark interview
