Subject: Restoring Database error:
anandprak
26 Feb 2008 8:12 AM
In my pc(m/c 1), local DNN(4.7) website which is working perfectly.I just locally hosted my website in another machine(2nd m/c) in which DNN(4.7) is already installed in it(viz.Copy all my dnn file folders except app data in 2nd m/c and taking the back up of db in 1st  m/c and restoring it in db of 2nd m/c  and modyfying web.config in 2nd m/c to access local db.when i run default.aspx, i get following error.But before restoring my db files in 1st m/c to my znd m/c,default.aspx was running perfectly in my 2nd m/c.Anyone who knows solution or sugestion, pls reply.
Server Error in '/DNN' Application.
The stored procedure 'dbo.GetPortalAliasByPortalID' doesn't exist.
Exception Details: System.InvalidOperationException: The stored procedure 'dbo.GetPortalAliasByPortalID' doesn't exist.
Source Error:
<span style="font-size: 10pt; color: black;">An
  unhandled exception was generated during the execution of the current web
  request. Information regarding the origin and location of the exception can
  be identified using the exception stack trace below.</span>
Stack Trace:
[InvalidOperationException: The stored procedure 'dbo.GetPortalAliasByPortalID' doesn't exist.]
   System.Data.SqlClient.SqlCommand.DeriveParameters() +878696
   System.Data.SqlClient.SqlCommandBuilder.DeriveParameters(SqlCommand command) +88
   Microsoft.ApplicationBlocks.Data.SqlHelperParameterCache.DiscoverSpParameterSet(SqlConnection connection, String spName, Boolean includeReturnValueParameter, Object[] parameterValues) +212
   Microsoft.ApplicationBlocks.Data.SqlHelperParameterCache.GetSpParameterSetInternal(SqlConnection connection, String spName, Boolean includeReturnValueParameter) +303
   Microsoft.ApplicationBlocks.Data.SqlHelperParameterCache.GetSpParameterSet(String connectionString, String spName, Boolean includeReturnValueParameter) +154
   Microsoft.ApplicationBlocks.Data.SqlHelperParameterCache.GetSpParameterSet(String connectionString, String spName) +36
   Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteReader(String connectionString, String spName, Object[] parameterValues) +200
   DotNetNuke.Data.SqlDataProvider.GetPortalAliasByPortalID(Int32 PortalID) +87
   DotNetNuke.Entities.Portals.PortalAliasController.GetPortalAliasByPortalID(Int32 PortalID) +35
   DotNetNuke.Entities.Portals.PortalSettings.GetPortalAliasLookup() +74
   DotNetNuke.Entities.Portals.PortalSettings.GetPortalAliasInfo(String PortalAlias) +14
   DotNetNuke.HttpModules.UrlRewriteModule.RewriteUrl(HttpApplication app) +3527
   DotNetNuke.HttpModules.UrlRewriteModule.OnBeginRequest(Object s, EventArgs e) +826
   System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +92
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +64
Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.42
26 Feb 2008 8:37 AM
Why did you not copy app_code?
Did you change portalalias in the moved database?
anandprak
26 Feb 2008 11:53 PM
I have copied the app_code as well.
No.I have not changed the portal alias in moved database.Can u please explain how to change portal alias in
moved database.
27 Feb 2008 8:12 AM
My recommendation is that you reveiw
To edit portalalias, you'll need SQL Server Management Studio Express (or the complete version).  Open your database, then open the portalalias table.  You can then edit it manually.
Forums > Users Lounge > Everything Else > Restoring Database error:
