Subject: What's the best CRM mod for DNN?
Daniel Doherty
22 Feb 2008 5:23 PM
Greetings and Salutations all!,
I require a flexible CRM (one I can add customised fields for, change pretty much anything in it) mod for DNN.
The client is a local ice hockey team and they need to track players, members etc.
I've looked at Singma Pro Draconis and Active CRM server / DNN mod; but wondering what else is out there?
Has anyone had any experience using these or got a better idea?
Cheers,
Dan
digmike
22 Feb 2008 9:18 PM
Hi Dan,
Check out splendidcrm.com. There is talk about DNN integration, but I don't think anything has solidified yet. It's ASP.NET and SQL and there is an Open Source version.
Mike
dignuke.com
Daniel Doherty
22 Feb 2008 10:37 PM
Hi Mike,
Great stuff. Thanks for that. Checking it out!
Cheers,
Dan
Will M
27 Feb 2008 5:31 AM
Make sure you read some of the posts about how Splendid is considering changing their licensing policy. Also, take a look a the number of bug reports versus regular posts. Splendid is a .NET port of SugarCRM.
Sigma Pro really excels as a project management/help desk tool. Active CRM is built from the ground up as a true CRM application with tight integration with DotNetNuke. Hope that helps.
Daniel Doherty
27 Feb 2008 5:48 AM
Hi Nuke Newbie,
Thanks for that. I have been looking at Sigma Pro and Active CRM and I think I was favouring Active Over Sigma. So it will be interesting. I will had a quick look at Splendid, and was turned off by the pricing. Hopefully they seriously look at it.
Thanks for letting me know.
Cheers,
Dan
Forums > Users Lounge > Everything Else > What's the best CRM mod for DNN?
