Subject: FCKEditor adds not wanted tags
pfrauholle
20 Feb 2008 9:14 AM
Hi, knows anyone why the FCKEditor adds < p > tags to the pasted text. I've saw in the tutorial, there wasn't any < p > tags, when the text was pasted into the editor.
And when I enter an linebreak ( < enter > ), then the editor makes a mess with the text, for example it added < p >....< / p >.
That's not what I want to achieve. Has anyone an idea, how to fix this.
Thanks pfrauholle
pfrauholle
20 Feb 2008 10:58 PM
in my message above there are some hidden text...with tags (above) I meant p tags, which is added to the editor when text is pasted or even if I do line breaks.
Thanks for any help on this...pfrauholle
Forums > Users Lounge > Everything Else > FCKEditor adds not wanted tags
