Subject: DNN database error
anandprak
19 Feb 2008 11:55 PM
In my pc(m/c 1), local DNN(4.7) website which is working perfectly.I just locally hosted my website in another machine(2nd m/c) without installing the DNN in it(viz.Copy all my dnn file folders except app data in 2nd m/c and taking the back up of db in 1st  m/c and restoring it in db of 2nd m/c  and modyfying web.config in 2nd m/c to access local db.
Now  all static pages are visible and my problem is that in all db related pages i get the following Error:
File Error: Failed to update database "DNN" because the database is read only.
Even when i click the FAQS and ContentLinks, i get the same error.
Anyone who knows solution or suggestion.pls reply.Thanks.
21 Feb 2008 7:24 AM
When you moved the database, you didn't give the login user the correct set of permissions for the database. You'll need to give that login write permission and, I think, ownership permissions.
Forums > Users Lounge > Everything Else > DNN database error
