Subject: remove module after upgrade, error
rogerg1967
17 Feb 2008 6:01 PM
I have made a mistake when upgrading a website. I should have removed 2 modules which dont work on the new version of DNN. I tested the install on my local pc then uploaded the files without removing the modules. Can I remove these manually?
this is the eror message I am getting.
[HttpException (0x80004005): The files '/App_Code/Reports/ReportsClientAPI.vb' and '/App_Code/DnnSiteMap/ExtendedTreeNode.cs' use a different language, which is not allowed since they need to be compiled together.]
   System.Web.Compilation.BuildProvidersCompiler.ProcessBuildProviders() +957
   System.Web.Compilation.BuildProvidersCompiler.PerformBuild() +29
   System.Web.Compilation.CodeDirectoryCompiler.GetCodeDirectoryAssembly(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories, Boolean isDirectoryAllowed) +387
   System.Web.Compilation.BuildManager.CompileCodeDirectory(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories) +125
   System.Web.Compilation.BuildManager.CompileCodeDirectories() +525
   System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompiled() +448
   System.Web.Compilation.BuildManager.ReportTopLevelCompilationException() +57
   System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompiled() +612
   System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters) +521
   System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +3540923
   System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +69
   System.Web.HttpRuntime.ProcessRequestInternal(HttpWorkerRequest wr) +275
Regards
Roger
rogerg1967
18 Feb 2008 3:18 AM
I have decided to go back to my origional site. I have uploaded the origional files. I am now getting the following error,
Server Error in '/' Application.
Object reference not set to an instance of an object.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Stack Trace:
<PRE>[NullReferenceException: Object reference not set to an instance of an object.]
   DotNetNuke.HttpModules.UrlRewriteModule.OnBeginRequest(Object s, EventArgs e) +962
   System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +92
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +64
</PRE>
is this becaues the database has started to update? or is it a different issue?
Regards
Roger
18 Feb 2008 7:45 AM
If I were you, I'd go back to the original database and web directory, and then remove the modules using the tools built in to DotNetNuke to do that.
Then I would use the resulting database and web directory as the starting point to do the upgrade.
Forums > Users Lounge > Everything Else > remove module after upgrade, error
