Subject: Problems with SlideshowPro and Dotnetnuke
pfrauholle
13 Feb 2008 11:13 PM
Hi, I've bought a license of SlideshowPro which is Flash. Now I have problems to include this into my skin file in Dotnetnuke.
The slideshow includes the swf, xml file and a folder with images.
Apart from using it in the skin file I tried using it with the media module, but it doesn't work. I tried different locations (portal/0/...) for the files, but without any success.
With the media module it shows only the flash background, but it didn't load any images from the xml file.
Please can someone come up with an idea where all the files are have to be located?
Thanks in advance
Patricia
14 Feb 2008 4:01 AM
At a guess the images will need to be in your skin zip file. - but you will need to ensure that the XML file has the correct URL for the images. - I have not set this up before so I'm taking a stab in the dark,
pfrauholle
14 Feb 2008 9:24 PM
Hi Lee, thanks for the quick answer. I managed to get it worked, but without my javascript which I included. The javascript code should handle the grey border in IE. For that I have a external javascript file, which pointed to the index.htm file within my skin folder.
Do you have an idea, where I have to include the javascript within Dotnetnuke or do you know some other ways how I can avoid the ugly looking flash border in IE?
Many thanks in advance...Patricia
15 Feb 2008 2:45 AM
  If you are wanting to work with an external JavaScript file, have a look here: Incorporating sIFR (Scalable Inman Flash Replacement) with DotNetNuke skins
scroll to the bottom and there are some key points for Video 5 which outlines adding JavaScript to DotNetNuke for 4.3+
pfrauholle
15 Feb 2008 8:02 AM
...thanks!
Forums > Users Lounge > Everything Else > Problems with SlideshowPro and Dotnetnuke
