Subject: What version of dotnetnuke should I install?
lolorn
12 Feb 2008 7:05 AM
I've been experimenting with an install of DNN version 4.05.03 and have used it to as a test site to build skins and try out modules like the snapsis menu and various others. I've now been asked to select a version to use to build the real site and I'm not sure what to choose. Version 4.05.03 doesn't seem to be available anymore and there have been quite a few upgraded versions out in the past couple of months.
The only thing I'm transfering on the test site to the real one will be a skin that uses the snapsis menu. What version of DNN should I select?
12 Feb 2008 12:31 PM
All of the old versions of DotNetNuke can be download from SourceForge. Follow the download links and look for the link to the archives.
BUT ... I would recommend that you just use 4.8.0. If you are using Active Directory integration, drop back to 4.7.0, but only for that reason.
Forums > Users Lounge > Everything Else > What version of dotnetnuke should I install?
