Subject: simultaneous redirection and data insertion issue
anandprak
11 Feb 2008 10:58 PM
Inside iframe module in my local dnn home page on single button click iam inserting some data in database and at the same time i want to redirect it to another main page of dnn.
Right now i on single button click,i have managed to insert data in database and simultaneously redirected to another page within the iframe module.
if simultaneously i try to redirect it to main page of my local dnn(4.7), then it gets redirected but the data does not get inserted in database.
If anyone knows solution or suggestion for this,pls reply.
12 Feb 2008 12:33 PM
I have no idea if anything like this is possible.
Remember that all that iFrame is doing is to render and external site's page inside of your site. There's no real integration going on ...
Forums > Users Lounge > Everything Else > simultaneous redirection and data insertion issue
