Subject: Logins to Child portal using Parent logins
dnnuknewbie
08 Feb 2008 8:40 AM
Greetings,
I need to allow users access to a child portal via parent logins. Is this possible or do i need a third party add on. Please can you tell me the best module to enable this.
Regards.
08 Feb 2008 9:00 AM
There are third party modules that do this. Check Snowcovered.com.
dnnuknewbie
08 Feb 2008 9:16 AM
Hello, thanks for that, please can you tell me the best module available. That would be helpful. Regards.
08 Feb 2008 11:16 AM
I haven't ever used a module to do that, so I can't make a recommendation.
If you use one and find it helpful, drop a note here so that we'll all know.
Forums > Users Lounge > Everything Else > Logins to Child portal using Parent logins
