Subject: Host is not a user in my userlist
nagakota
30 Jan 2008 4:35 AM
I need to login as Host to add a new file type for upload.  But I do not even see Host as one of the users in the SQLServer database or in the list of users when I login as Portal Admin.
30 Jan 2008 7:45 AM
That's correct. Technically, Host is not a user. You manage host accounts from the Host Accounts page under the Host menu.
Forums > Users Lounge > Everything Else > Host is not a user in my userlist
