Subject: Help with OnyakTech SigmaPro
lprager
20 Jan 2008 9:38 PM
Does anyone have experience with SigmaPro from OnyakTech? In particular, I am trying to setup a help desk and live chat. I got live chat to work but I cannot piece together how SigmaPro works, how to set it up, or how to use it.
I have tried to communiate with OnyakTech about the lack of documentation but all I get is pointers back to random pages on their web site that have incomplete bits of information.
If anyone has some good documentation or experience on this product I would really like to try and understand it.
OnyakTech
22 Jan 2008 6:46 PM
All of the information for SigmaPro is on www.SigmaProDraconis.com.  Check both the How To and the Advanced tabs.  Additional information may be found in the forums and from the Support page on www.OnyakTech.com. If you let me know what specifically you need help with, I will detail it for you.
Forums > Users Lounge > Everything Else > Help with OnyakTech SigmaPro
