Subject: photos of knockoffs
neojapanese
17 Jan 2008 9:52 AM
someone posted photo of knock offs on my site
i told the member that i would remove his account. he said he should be able to post as long as he didnt post a price. i dont know the law. anyone know if this is true. is it ok to post a photo of a knock of item as long as you dont say the price. its not like there is a paypal link or anything
17 Jan 2008 1:38 PM
Well my own personal opinion is you are in charge, so you make the rules, if you don't want it on there tell them and delete the images. You have to remember it is the reputation of your website on the line.
On any sites I run if something is posted that is not suitable I just remove it, don't let them get away with bending your own rules ;-) It might be worth posting a note in your guidelines stating 'no knock off items' etc.
Cheers,
Forums > Users Lounge > Everything Else > photos of knockoffs
