Subject: TreeView
tmak
18 Dec 2007 5:03 PM
I am looking for a TreeView-like control which is able to hold 2 levels of links. Initially the top level links will be shown. If I selected a particular top level link, 2 things will happen, 1) expand all the 2nd level links, and 2) allow me to navigate to top level link in another pane. Is the control exist in V4.7? If not, is there any external modules which provide similar functionality?
Thanks for your help.
tm
WOW GOLD by wowgolds987
RE: Pop up window by yerann
RE: Events calendar by mjbieg
