Subject: Help with simple User Control
altein
10 Dec 2007 8:03 AM
I am trying to make a barebones user control for a module in DotNetNuke.  I apologize if this isn't the right forum.   The module compiles and can be added to the list of available modules in the Control Panel:  But in the container, I receive the following error.  The name of the control is Login2.  It simply outputs the information entered by the user in a login box.
This is the error I receive
Error: Login2 is currently unavailable.
DotNetNuke.Services.Exceptions.ModuleLoadException: Unable to cast object of type 'ASP.admin_skins_login_ascx' to type 'DotNetNuke.Entities.Modules.PortalModuleBase'. ---> System.InvalidCastException: Unable to cast object of type 'ASP.admin_skins_login_ascx' to type 'DotNetNuke.Entities.Modules.PortalModuleBase'. at DotNetNuke.UI.Skins.Skin.InjectModule(Control objPane, ModuleInfo objModule, PortalSettings PortalSettings) --- End of inner exception stack trace ---
Here is the code for the user control named Login2.ascx
<%@ Control Language="VB" AutoEventWireup="false" CodeFile="Login2.ascx.vb" Inherits="AlteinEnterprises.CoffeeShopListing.Login2" %>
<table style="border-style:solid; border-color: Black;">
tr>
  <td><b>Loginb>td>
  <td><asp:TextBox ID="User" runat="server" />td>
tr>
tr>
<td><b>Passwordb>td>
<td><asp:TextBox ID="Pass" runat="server" />td>
tr>
tr>
<td>td>
<td><asp:Button id="buttton" Text="Submit" runat="server" />td>
tr>
table>
p><asp:Label ID="lblMessage" runat="server" />p>
This is the code-behind for the user control
Imports DotNetNuke
Namespace AlteinEnterprises.CoffeeShopListinga
Partial Class Login2
Inherits Entities.Modules.PortalModuleBase
Public UserName As String
Public Password As String
Public Sub Submit(ByVal Sender As Object, ByVal e As EventArgs)
lblMessage.Text = "UserName: " & User.Text & _
& "Password: " & Pass.Text & ""
End Sub
End Class
End
Namespace
I do not know why I am receiving this error and I would be so very appreciative if some one could help me out.
altein
10 Dec 2007 8:16 AM
If that's not a transcription error, remove the "a" at the end of the line.
altein
10 Dec 2007 8:31 AM
the 'a' is just a typo. In my code, it doesn't exist. It is only AlteinEnterprises.CoffeeShopListing
altein
10 Dec 2007 8:48 AM
Looking more ... the error messages seem to refer to the skin. Are you including this module in your skin?
One way to go about debugging this would be to install a version of DNN on a local computer, add this module and skin, and then run the web site under Visual Web Developer or Visual Studio. If you do that you can check for compile errors, set breakpoints, etc. That would probably help you locate the source of the problem more easily.
10 Dec 2007 9:10 AM
Oh, just another thought. If you are trying to mimic the DotNetNuke login module, you might want to take a look at it's source. In particular, the code-behind for that "Inherits UserModuleBase" which is different than your code.
altein
10 Dec 2007 9:22 AM
Dear Mr. Craig,
Thank you so much for your advice and information.  It turns out I just had the "login" user control, login.ascx, set as the control for the "login2" (the module I created) module in the module definitions.  I just changed the user control for the module "login2" to the login2.ascx.
My apologies,
Thanks again
10 Dec 2007 9:24 AM
Super!
Forums > Users Lounge > Everything Else > Help with simple User Control
