Subject: Adding a field to register form
dnnuknewbie
21 Nov 2007 6:12 AM
Greetings,
I am attempting to add a field (Organisation) to a child register form. I have added it to the property profile but i can't seem to get it to highlight on the form. Any ideas. Thanks.
21 Nov 2007 9:18 AM
You'll want to make that new field "required" and you'll also want to visit the "User Settings" page (from the Users tab) and check the box to "Require a valid profile for registration."
Forums > Users Lounge > Everything Else > Adding a field to register form
