Subject: Accept terms check box
rogerg1967
20 Nov 2007 3:50 PM
I have followed your tutorial on how to create an accept terms check box. I am using DNN 4.5.5. The issue I am having is the the check box is not appearing on the registration page. It is on the user profile page. I need it to be on the registration page. is this an issue with DNN 4.5.5? How can I fix it?
Regards
Roger Goodwin
21 Nov 2007 9:23 AM
Go to the "User Settings" page (you will find a link from the Users page) and check the box for "Require a valid Profile for Registration." Also check the similar box for login.
Forums > Users Lounge > Everything Else > Accept terms check box
