Subject: module request
dnnuknewbie
28 Oct 2007 4:37 AM
Greetings.
Pls can someone refer me to a suitable module that will create content for say a client within their user account. For example, i want to be able to create a login for a client in say a security group called clients work and as soon as a particular client logs in, they have access to page content just for them. At the moment i can see that this is possible if i create security roles for each client but i am looking for an easier way of doing this.
Thanks.
28 Oct 2007 10:33 AM
With the newest version of DotNetNuke you can assign rights to pages and modules by username as well as by role. So, you could have pages and or modules viewable by everyone, clients, client groups, username, etc.
dnnuknewbie
28 Oct 2007 1:45 PM
Brilliant. Thanks for that. That should work well. Thanks.
