Subject: Best Blog module or service
dnnuknewbie
28 Oct 2007 4:32 AM
Greetings,
Please tell me the best blog software for DNN or the best external blog software users have found. Thanks.
28 Oct 2007 10:36 AM
If you don't like the DotNetNuke blog module, others have found the Ventrian News Module to be a useful one.
dnnuknewbie
28 Oct 2007 1:55 PM
To be honest i don't have an opinion on the dnn blog module as i haven't used it. I was hoping to hear from users their opinions on the best blog software (all the better if it fits in with DNN) thanks.
Forums > Users Lounge > Everything Else > Best Blog module or service
