Subject: Re: search box
dnnuknewbie
28 Oct 2007 4:30 AM
Greetings,
With the new search box layout giving users an opportunity to search within the dnn site or on the web is it possible to add in site:www.mydnnsite.com before this search so that first results are from the dnn site.
Thanks.
28 Oct 2007 10:38 AM
The search in the "dnn" site is within your site.
dnnuknewbie
28 Oct 2007 1:47 PM
On the newer versions, it gives an option to search within the dnn site as well as a radio button that allows a search from this search box to the web. I am interested in knowing how to configure the web search. Thanks.
30 Oct 2007 3:01 PM
I haven't come across any information for configuring the actual web search, if you find any let us know as this will be very interesting. - The only information I have come across is how to configure the display ie. - to display the web search radio buttons or not
gp
21 Nov 2007 4:46 PM
I've spent 30 minutes or so googling for how to set up search.aspx for "web" rather than site and found *nothing*?? How is this possible?
26 Nov 2007 5:11 AM
If you look at one of the free skins on DNN creative you can look in the skin.xml file and look at the settings for the search token. - you should be able to change the settings here so that it just displays the option to search the web.
< Object >
    < Token >[SEARCH]< /Token >
    < Settings >
      < Setting >
        < Name >CssClass< /Name >
        < Value >SkinItem< /Value >
      < /Setting >
      < Setting >
        < Name >ShowSite< /Name >
        < Value >False< /Value >
      < /Setting >
      < Setting >
        < Name >ShowWeb< /Name >
      < /Setting >
    < /Settings >
  < /Object >
 so in one of those skins, set showweb to True
gp
26 Nov 2007 11:12 AM
True, I can show it but where is the rest of the control? Which search page? Where are the link properties? Thats what I have been looking for... thx for your response.
28 Nov 2007 4:40 AM
After a bit of testing in the DNN blue skin, it doesn't seem to work that well. -   The first search works and opened Google with the search results, after that it would not perform a search.
You can configure the search results page - but this only configures the search results for searches within your DotNetNuke installation. - I have not looked at the web search any further, if you find any information let us know.
One question I do have is, if you implement adsense on your website you have the option to display links to search results, - I wonder if it is possible to get a Google affiliate link in the web search results from your DNN portal?
