Subject: user profile custom list menu
rogerg1967
24 Oct 2007 3:57 AM
I am trying to add a custom field to my user profiles. I have followed your tutorial. I have added the list name and populated it with names. When i try to edit a user profile the list is empty.
I am using DNN 4.5.5.
Any ideas
24 Oct 2007 9:52 AM
If the name of the dropdown list has spaces in it, the list won't display properly. This is a bug in DotNetNuke. It is fixed in 4.6.2.
If you need to continue to use 4.5.5, use a list name with no spaces. Use the localized text to display friendlier text to the user.
Forums > Users Lounge > Everything Else > user profile custom list menu
