Subject: DNN 4.5.5 ssl issues
rshevlin
23 Oct 2007 8:31 PM
In DNN455 page settings there is a check box on page settings other which is a security checkbox which is disabled. In ? it says admin must allow this in site settings. Cant find anyway to do tyhis in site settings. With Catalook store there is no way to enter SSL on page that client enters user data for a purchase when using authorize.net. Anyone have an answer
24 Oct 2007 1:38 AM
SSL settings are enabled and configured under the Advanced Settings section of Site settings.
There is an article about configuring SSL here.
Forums > Users Lounge > Everything Else > DNN 4.5.5 ssl issues
