Subject: Why does the submenu image repeats?
jamx551
23 Oct 2007 12:44 PM
Pls see  http://mngts.encumpus.com/Portals/138/image/submenuissue.jpg
I tried reducing the width of the submenu but it doesnt work.. I also included display:none inside icon and arrow but still nothing happens..
My css for the menu is this :
.MainMenu_MenuContainer
 width:190px;
  height:22px;
.MainMenu_MenuBar {
    cursor: pointer;
    cursor: hand;
.MainMenu_MenuItem
    cursor: pointer;
    color: #0F3C1D;
    font-family: Arial, Tahoma;
 padding-left: 4pt;
   background-image: url(menu.jpg);
    font-size: 13px;
    font-weight: bold;
    font-style: normal;
  width:192px;
  height:22px;
.MainMenu_SubMenu {
    z-index: 1000;
    cursor: pointer;
  border:0;
  width:170px;
  height:22px;
    font-size: 13px;
     font-weight: bold;
    font-style: normal;
.MainMenu_MenuIcon
    display: none;
   border:0;
.MainMenu_MenuItemSel
    cursor: pointer;
    color: #ff5206;
    padding-left: 4pt;
    font-size: 13px;
  height:22px;
    font-weight: bold;
    font-style: normal;
 background-image: url(menuover.jpg);
.MainMenu_SubMenuItemSelected
    border: 0px;
 color: #000063;
.MainMenu_MenuArrow
    display: none;
   border:0;
.MainMenu_MenuBreak {
 height: 0px;
.SelectedMenu
 color:#ffffff;
 text-decoration:none;
jamx551
23 Oct 2007 1:16 PM
The extra space in the submenu is really annoying and it even repeats the background image.. can anyone help?
30 Oct 2007 4:30 PM
Have you tried using:
background-repeat: no-repeat;
in the .MainMenu_MenuItem
jamx551
31 Oct 2007 8:49 AM
yes Lee Ive tried that but got the same result.. What else could be wrong?
Forums > Users Lounge > Everything Else > Why does the submenu image repeats?
