Subject: problem with videos
john20
23 Oct 2007 10:49 AM
Hi Expert,
I am very new to DotNetNuke, i i dont know where to place this qurey in the forum section.
I want to download tutorial videos from this site,how can i download the videos.
can u please let me know the procedure to download the videos for the tutorial as i am finding dififculties to download the videos,it is asking me to login to download the videos,but after login also i am not able to download it.
any help will be appriciated.
-john
23 Oct 2007 11:06 AM
There are some videos available for free, others you need to subscribe to the website to access. - To view the free content have a look here: http://www.dnncreative.com/Home/FreeContent/tabid/101/Default.aspx
This is a good starting video:
Quick Start Guide to DotNetNuke
If you login and view the link above you should see at the bottom of the page links to the videos. - Let us know if you are still having problems, thanks,
Lee
Forums > Users Lounge > Everything Else > problem with videos
