Subject: Solpart & Sub-Menu Question
Marcusw
22 Oct 2007 7:22 AM
I'm sorry... I'm sure this question must have been asked lots of times.
What I want is a way to have a top-level horizontal menu and when an item is clicked the resulting tab shows a vertical left-justified menu that is relevent to the item that has been clicked. Simple stuff really but I'm not sure if/how this can be achieved with the SolPart default menu control.
Any thoughts gratefully received.
Marcus.
22 Oct 2007 8:45 AM
I know that you can do this with the Snapsis Nav Menu, but I don't know if you can do this with SolPart menu.
23 Oct 2007 10:28 AM
This may help: SolPart Menu Uncovered
Forums > Users Lounge > Everything Else > Solpart & Sub-Menu Question
