Subject: dnn 4.5.5 user profile lists dont work
rogerg1967
21 Oct 2007 4:45 PM
Hi, I have been trying to create extra fields for my user forms. I have added text fields etc. The issue I have is that when I try to add a drop down list the values dont appear. I have followed your tutorial and when it comes to editing the profile.ascx file the detail in the file is different. I think its to do with the vers. of DNN i am using. Do you know of any issues if so are there any work arounds.
22 Oct 2007 8:53 AM
If the name of your dropdown list has spaces in it, then it won't display correctly. This appears to have been corrected in 4.6.2.
I think that there was also a problem with DateTime, and this also seems to work in 4.6.2.
22 Oct 2007 9:03 AM
Oh, the solution for drop down boxes is to use a name that has no spaces. You can use the localized text to control what is displayed to the user.
Forums > Users Lounge > Everything Else > dnn 4.5.5 user profile lists dont work
