Subject: changing a child to a parent portal
topoulos
19 Oct 2007 10:51 AM
Hi!
I have a question:  How do I change a child portal into a parent portal.  Is this hard?  I was thinking of developing the site as a child, but then changing it to where it can be directly accessed via an IP.  the site would be on the same server and database as it is now.
-Tony
19 Oct 2007 11:25 AM
No this is not hard, I would have a look at:
DotNetNuke Portal Aliases
which demonstrates how to convert a child portal to a parent, this tutorial may also be of interest
How to create DotNetNuke Portals (Parent and Child) have a look at Issue no 17
as this is all related to portals
Forums > Users Lounge > Everything Else > changing a child to a parent portal
