Subject: Search Engine Question
DavidWSnow
18 Oct 2007 3:47 PM
Why is that Google lists most of use like this:
DotNetNuke with DNN Creative Magazine, Web Design, Tutorials ... - 10 visits - 1:42pm
DotNetNuke magazine covering module video reviews, video tutorials, resources and web design tips for working with DotNetNuke. Beginner to Advanced.
www.dnncreative.com/ - 63k - Cached - Similar pages - Note this
yet list other like this?
DotNetNuke > Home - 9 visits - Mar 15
DotNetNuke is an open source web application framework ideal for creating, deploying and managing interactive web, intranet, and extranet sites securely.
www.dotnetnuke.com/ - 101k - Cached - Similar pages - Note this
Downloads - www.dotnetnuke.com/tabid/125/default.aspx
Community Modules - www.dotnetnuke.com/.../tabid/794/Default.aspx
Showcase Sites - www.dotnetnuke.com/default.aspx?tabid=541
Projects - www.dotnetnuke.com/tabid/824/default.aspx
More results from dotnetnuke.com »
Is this a function of some magic on the page, RageRank, Cash, or some other magic.
Needless to say I think that my site would get more traffic with the second form of listing.
Anybody know the answer?
/DaveS
18 Oct 2007 4:13 PM
It tends to just provide the extra links for a site if it is at number one in the search. - It thinks the site is the most relevant search result, so it also provides further links into the site which it thinks will be of interest. - So if you want those extra links I think you just need to get your site to number 1 for your keyword search term.
DavidWSnow
18 Oct 2007 6:00 PM
You are #1 for "Dnn Creative" and it doesn't do it for you.  I think that there is more to it than #1.
19 Oct 2007 10:09 AM
yes you are probably right, I get 1 sub link underneath the main which links to the forum. - so incoming links probably has a feature in it as well. - perhaps you need to get several incoming links to those main pages to get them listed as categories under your main domain name. If you find any further information let us know.
- I recall reading an article some time ago about how to achieve this but I can't remember the full details or where I read it, I've just done a quick Google search and can't find the information either, so let me know if you find any further information as this is going to bug me!
Forums > Users Lounge > Everything Else > Search Engine Question
