Subject: load balancing
rogerg1967
15 Oct 2007 5:07 PM
I have been having an issue with a website which is being hosted with load balancing installed. I have had a lot of issues with the site not loading and giving errors. Is load balaning a complete no no with DNN 4.5.5 or is there a work around which might stop this happening? has anyone else had this issue?
16 Oct 2007 9:47 AM
This might be a question that is better asked on the DotNetNuke forums. Details of the errors would help, too.
