Subject: admin email issue
mattfarmer
10 Oct 2007 9:40 AM
I have a hosted domain and 2 other portals under the main domain.
I am admin on all portals and i am trying to change the admin email address on each portal so it is different.
At the moment if i change the admin email address on one portal it changes the admin email address on the other 2 portals aswell to the same address.
Is this normal or am i doing something incorrect.
Cheers,Matt.
11 Oct 2007 2:42 AM
That's strange. - Make sure you are viewing the correct portal when logging in as the administrator for that portal and you should be able to change the email address for the administrator user without it affecting the other accounts
Forums > Users Lounge > Everything Else > admin email issue
