Subject: Your Thoughts on DNN4.6x compliance
pspeth
03 Oct 2007 8:54 AM
I understand that they finally made some updates in 4.6x to become more xhtml compliant.
I would like to here your thoughts on the changes.
Have they gone far enough?
What additional changes would you like to see?
05 Oct 2007 11:06 AM
I haven't had chance to look through that version yet, but I will be going through this with Cathal when preparing for the opening force presentation in Nov. - I'm sure there are more changes planned for the future as well, thanks,
Forums > Users Lounge > Everything Else > Your Thoughts on DNN4.6x compliance
